Fpga_Egr_2025's avatar
Fpga_Egr_2025
1 year ago
Gate Level Simulation
Hi ,
I am trying to run gate level simulation for my uart implementation, but for some reason the Questasim complains about UUT binding not correct . Although in RTL simulation it works fine.
See below my UART Top and UART TB code. I also tried running a TCL recommended in the Intel Quartus Simulation guide but it comes up with the same error.
-- UART TOP --
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
USE ieee.numeric_std.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
use IEEE.math_real.all;
-- Top level module
ENTITY UART_Top IS
generic (LEDG_WIDTH : integer := 9;
LEDR_WIDTH : integer := 18;
SW_WIDTH : integer := 18;
GPIO_WIDTH : integer := 37
PORT (
CLOCK_50 : IN STD_LOGIC;
UART_TXD : OUT STD_LOGIC;
-- Switches
SW : IN STD_LOGIC_VECTOR(SW_WIDTH-1 DOWNTO 0);
-- Push Buttons
KEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
-- LEDs
LEDG : OUT STD_LOGIC_VECTOR(LEDG_WIDTH-1 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR(LEDR_WIDTH-1 DOWNTO 0);
GPIO : INOUT STD_LOGIC_VECTOR(GPIO_WIDTH-1 DOWNTO 0)
end UART_Top;
architecture Uart_tx_STRUCTURE of UART_Top is
-- UART Transmitter --
component TX is
port ( clk : IN STD_LOGIC;
Reset : IN STD_LOGIC;
Start : IN STD_LOGIC;
Baud_Rate : IN INTEGER;
Data : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
Done : OUT STD_LOGIC;
Running : OUT STD_LOGIC;
TX_Data : OUT STD_LOGIC);
end component TX;
-- UART Test bench --
entity UART_TB is
end UART_TB;
LIBRARY ieee ;
architecture Testing_UART of UART_TB is
-- TB constants --
constant LEDG_WIDTH : integer := 9;
constant LEDR_WIDTH : integer := 18;
constant SW_WIDTH : integer := 18;
constant GPIO_WIDTH : integer := 37;
component UART_Top IS
PORT (
CLOCK_50: IN STD_LOGIC;
-- Switches
-- Push Buttons
-- LEDs
end component;
-- gate sim TCL --
vcom -2008 UART_Top.vho
vsim -t ps -L work UART_TB
add wave -r /*
run -all
quit
-- Error --
Errors: 0, Warnings: 0
# vsim -t ps -L work UART_TB
# Start time: 10:17:46 on Aug 26,2025
# ** Note: (vsim-3812) Design is being optimized...
# ** Error (suppressible): C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(56): (vopt-1271) Bad default binding for component instance "UUT: UART_Top".
# (Component generic "GPIO_WIDTH" is not on the entity "work.UART_Top".)
# (Entity is selected because it is in the same library as the design unit that contains the component.)
# Optimization failed
# ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=2, Warnings=1.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./gate_sim.do PAUSED at line 2
  • Hi OP,
    Hopefully, the example code provided in the github is sufficient as a reference to run the gate-level simulation successfully.
    With that, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
    Richard Tan
  • AlanCLTan's avatar
    AlanCLTan
    The comparison of your component declaration in the testbench and the component declaration of UART_Top, one port is found missing:
    Even though the error message complains about GPIO_WIDTH, the actual issue is likely due to incomplete port matching between the component and the entity.
    Please check again.
    Alan Tan
    • Fpga_Egr_2025's avatar
      Fpga_Egr_2025
      Hi Alan,
      Thanks for pointing that out , i did corrected the UUT binding. But i am still getting the same error.
      I tried deleting the UART_Top.vho file , compiled the files again in quartus. Simulated again in RTL and then Gate level but Questasim is still stuck at this error .
      entity UART_TB is
      end UART_TB;
      LIBRARY ieee ;
      -- TB constants --
      PORT (
      -- Switches
      -- Push Buttons
      -- LEDs
      end component;
      signal Clock_50_tb, UART_TX_tb : STD_LOGIC;
      signal LEDR_tb, SW_tb : STD_LOGIC_VECTOR(SW_WIDTH-1 DOWNTO 0);
      signal LEDG_tb : STD_LOGIC_VECTOR(LEDG_WIDTH-1 DOWNTO 0);
      signal KEY_tb : STD_LOGIC_VECTOR(3 DOWNTO 0);
      signal GPIO_tb : STD_LOGIC_VECTOR(GPIO_WIDTH-1 DOWNTO 0);
      BEGIN
      -- instantiate the component under test
      UUT: UART_Top
      generic map( LEDG_WIDTH => LEDG_WIDTH,
      LEDR_WIDTH => LEDR_WIDTH,
      SW_WIDTH => SW_WIDTH,
      GPIO_WIDTH => GPIO_WIDTH
      PORT MAP(
      CLOCK_50 => Clock_50_tb,
      UART_TXD => UART_TX_tb,
      SW => SW_tb,
      KEY => KEY_tb,
      LEDG => LEDG_tb,
      LEDR => LEDR_tb,
      GPIO => GPIO_tb
      --Questasim Error ------------------------
      # Start time: 17:36:29 on Aug 26,2025
      # ** Error (suppressible): C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1271) Bad default binding for component instance "UUT: UART_Top".
        Fpga_Egr_2025
        Hi Alan,
        I modified the tb code as follows :
        entity UART_TB is
        end UART_TB;
        LIBRARY ieee ;
        -- TB constants --
        -- generic (LEDG_WIDTH : integer := 9;
        -- LEDR_WIDTH : integer := 18;
        -- SW_WIDTH : integer := 18;
        -- GPIO_WIDTH : integer := 37
        PORT (
        -- Switches
        -- Push Buttons
        -- LEDs
        end component;
        BEGIN
        UUT: UART_Top
        --generic map( LEDG_WIDTH => LEDG_WIDTH,
        -- LEDR_WIDTH => LEDR_WIDTH,
        -- SW_WIDTH => SW_WIDTH,
        -- GPIO_WIDTH => GPIO_WIDTH
        PORT MAP(
        SW => SW_tb,
        KEY => KEY_tb,
        LEDG => LEDG_tb,
        LEDR => LEDR_tb,
        GPIO => GPIO_tb
        --------- Questasim Error messages ------------------------------------
        # Start time: 11:36:33 on Aug 27,2025
        # ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "UART_TXD" in component "UART_Top" when binding to entity "UART_Top".
        # ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "LEDG" in component "UART_Top" when binding to entity "UART_Top".
        # ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "LEDR" in component "UART_Top" when binding to entity "UART_Top".
        # ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "GPIO" in component "UART_Top" when binding to entity "UART_Top".
        # ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=8, Warnings=1.
        Now it is detecting incompatible modes for ports.
    AlanCLTan
    Could you try an experiments to see if it solves the error:
    1. Remove the generic entity declaration, including GPIO_WIDTH, from the component declaration?
    component UART_Top
    port (
    -- your ports here
    end component;
    Remove the generic map from the instantiation?
    UUT: UART_Top
    port map(
    -- your port mappings
    Alan Tan
  • RichardT_altera's avatar
    RichardT_altera
    Thank you Alan for the answer.
    I suspect there might be an issue with your design. You could try searching for publicly available UART designs for reference.
    You may check out the webpage below, although the design is written in Verilog.
    https://github.com/varmil/uart-verilog
    I was able to simulate their design successfully.
    Richard Tan
      Fpga_Egr_2025
      Hi Alan,
      Thanks for your reply , i have to stick to VHDL implementation i will search or modify the code .
    RichardT_altera
    Hi OP,
    Richard Tan
