Gate Level Simulation
- 1 year ago
Hi OP,
Hopefully, the example code provided in the github is sufficient as a reference to run the gate-level simulation successfully.
With that, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
The comparison of your component declaration in the testbench and the component declaration of UART_Top, one port is found missing:
UART_TXD : OUT STD_LOGIC;
Even though the error message complains about GPIO_WIDTH, the actual issue is likely due to incomplete port matching between the component and the entity.
Please check again.
Alan Tan
- Fpga_Egr_20251 year ago
Hi Alan,
Thanks for pointing that out , i did corrected the UUT binding. But i am still getting the same error.
I tried deleting the UART_Top.vho file , compiled the files again in quartus. Simulated again in RTL and then Gate level but Questasim is still stuck at this error .
entity UART_TB isend UART_TB;LIBRARY ieee ;USE ieee.std_logic_1164.all ;USE ieee.numeric_std.all;use IEEE.std_logic_arith.all;use IEEE.std_logic_unsigned.all;use IEEE.math_real.all;architecture Testing_UART of UART_TB is-- TB constants --constant LEDG_WIDTH : integer := 9;constant LEDR_WIDTH : integer := 18;constant SW_WIDTH : integer := 18;constant GPIO_WIDTH : integer := 37;----------------------------------component UART_Top ISgeneric (LEDG_WIDTH : integer := 9;LEDR_WIDTH : integer := 18;SW_WIDTH : integer := 18;GPIO_WIDTH : integer := 37);PORT (CLOCK_50 : IN STD_LOGIC;UART_TXD : OUT STD_LOGIC;-- SwitchesSW : IN STD_LOGIC_VECTOR(SW_WIDTH-1 DOWNTO 0);-- Push ButtonsKEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0);-- LEDsLEDG : OUT STD_LOGIC_VECTOR(LEDG_WIDTH-1 DOWNTO 0);LEDR : OUT STD_LOGIC_VECTOR(LEDR_WIDTH-1 DOWNTO 0);GPIO : INOUT STD_LOGIC_VECTOR(GPIO_WIDTH-1 DOWNTO 0));end component;--signal Clock_50_tb, UART_TX_tb : STD_LOGIC;signal LEDR_tb, SW_tb : STD_LOGIC_VECTOR(SW_WIDTH-1 DOWNTO 0);signal LEDG_tb : STD_LOGIC_VECTOR(LEDG_WIDTH-1 DOWNTO 0);signal KEY_tb : STD_LOGIC_VECTOR(3 DOWNTO 0);signal GPIO_tb : STD_LOGIC_VECTOR(GPIO_WIDTH-1 DOWNTO 0);-------------------------------------------------------------------BEGIN-- instantiate the component under testUUT: UART_Topgeneric map( LEDG_WIDTH => LEDG_WIDTH,LEDR_WIDTH => LEDR_WIDTH,SW_WIDTH => SW_WIDTH,GPIO_WIDTH => GPIO_WIDTH)PORT MAP(CLOCK_50 => Clock_50_tb,UART_TXD => UART_TX_tb,SW => SW_tb,KEY => KEY_tb,LEDG => LEDG_tb,LEDR => LEDR_tb,GPIO => GPIO_tb);-------------------------------------------------------------------------Questasim Error ------------------------# vsim -t ps -L work UART_TB
# Start time: 17:36:29 on Aug 26,2025
# ** Note: (vsim-3812) Design is being optimized...
# ** Error (suppressible): C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1271) Bad default binding for component instance "UUT: UART_Top".
# (Component generic "GPIO_WIDTH" is not on the entity "work.UART_Top".)
# (Entity is selected because it is in the same library as the design unit that contains the component.)
# Optimization failed
# ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=2, Warnings=1.
# Error loading design
# Error: Error loading design
# Pausing macro execution
# MACRO ./gate_sim.do PAUSED at line 2- Fpga_Egr_20251 year ago
Hi Alan,
I modified the tb code as follows :
entity UART_TB isend UART_TB;LIBRARY ieee ;USE ieee.std_logic_1164.all ;USE ieee.numeric_std.all;use IEEE.std_logic_arith.all;use IEEE.std_logic_unsigned.all;use IEEE.math_real.all;architecture Testing_UART of UART_TB is-- TB constants --constant LEDG_WIDTH : integer := 9;constant LEDR_WIDTH : integer := 18;constant SW_WIDTH : integer := 18;constant GPIO_WIDTH : integer := 37;----------------------------------component UART_Top IS-- generic (LEDG_WIDTH : integer := 9;-- LEDR_WIDTH : integer := 18;-- SW_WIDTH : integer := 18;-- GPIO_WIDTH : integer := 37-- );PORT (CLOCK_50 : IN STD_LOGIC;UART_TXD : OUT STD_LOGIC;-- SwitchesSW : IN STD_LOGIC_VECTOR(SW_WIDTH-1 DOWNTO 0);-- Push ButtonsKEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0);-- LEDsLEDG : OUT STD_LOGIC_VECTOR(LEDG_WIDTH-1 DOWNTO 0);LEDR : OUT STD_LOGIC_VECTOR(LEDR_WIDTH-1 DOWNTO 0);GPIO : INOUT STD_LOGIC_VECTOR(GPIO_WIDTH-1 DOWNTO 0));end component;--signal Clock_50_tb, UART_TX_tb : STD_LOGIC;signal LEDR_tb, SW_tb : STD_LOGIC_VECTOR(SW_WIDTH-1 DOWNTO 0);signal LEDG_tb : STD_LOGIC_VECTOR(LEDG_WIDTH-1 DOWNTO 0);signal KEY_tb : STD_LOGIC_VECTOR(3 DOWNTO 0);signal GPIO_tb : STD_LOGIC_VECTOR(GPIO_WIDTH-1 DOWNTO 0);-------------------------------------------------------------------BEGIN-- instantiate the component under testUUT: UART_Top--generic map( LEDG_WIDTH => LEDG_WIDTH,-- LEDR_WIDTH => LEDR_WIDTH,-- SW_WIDTH => SW_WIDTH,-- GPIO_WIDTH => GPIO_WIDTH-- )PORT MAP(CLOCK_50 => Clock_50_tb,UART_TXD => UART_TX_tb,SW => SW_tb,KEY => KEY_tb,LEDG => LEDG_tb,LEDR => LEDR_tb,GPIO => GPIO_tb);----------------------------------------------------------------------------
--------- Questasim Error messages ------------------------------------
# Start time: 11:36:33 on Aug 27,2025
# ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "UART_TXD" in component "UART_Top" when binding to entity "UART_Top".
# ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "LEDG" in component "UART_Top" when binding to entity "UART_Top".
# ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "LEDR" in component "UART_Top" when binding to entity "UART_Top".
# ** Error: C:/intelFPGA_lite/24.1std/quartus/qdesigns/HW_tested_verified_prjs/UART_TX_HW_test/UART_TB.vhd(58): (vopt-1134) Incompatible modes for port "GPIO" in component "UART_Top" when binding to entity "UART_Top".
# ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=8, Warnings=1.
# MACRO ./gate_sim.do PAUSED at line 2Now it is detecting incompatible modes for ports.
