FW_CODE_NOT_WORKING_WHEN_CONFIGURED_FPGA_WITH_JIC_PROGRAMMING
Hi Team,
We tried to check the jic file programming setup in Cyclone v gt eval board. For that we have created the system in FPGA design like this:
nios ii reset and exception vector parameter:
firmware code structure we have followed like this:
linker script and other parameters in bsp editor:
make target->mem_init gen used to create hex file.
JIC File conversion parameters setup:
with this jic, we have programmed the fpga, Our expected output from this is 3 led should blink( 1 controlled by FPGA DESIGN and other2 controlled by firmware code).
But with jic programming, firmware controlled led is not blinking.
But in .elf file programming, firmware controlled led is blinking.
do we miss anything? Please guide us to resolve this.
- Farabi_Altera
This is to let you know I am investigating your case.
I will get back to you once I have the solution for your issue.
regards,
Farabi
- EBERLAZARE_I_Intel
With your Exception Vector (RAM IP settings) set to OCRAM, you need your BSP as follows:
Re-build the BSP and project, and re-generate the new .hex using the "mem_init_generate" tools.
Replace your .hex with this new .hex (with above BSP settings) in Platform Designer and create your new .jic and re-try.
- SERMASWATHIKA
Contributor
Hi Eberlazare,
I have tried with the settings you have mentioned in above response, with that also firmware controlled led is not working.
the setting which i have used:
and i have one doubt that two hex files are generated in mem_init folder, i am using epcq hex file only for generating the jic file programming. Is that correct only right?
I think it is because of your Reset Vector offset in your first post, for EPCQ, you need to have offset address for your application as the .jic will also have the .sof at 0x0, so you do not want to overlap it. Anyway, you can find the info here:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/reset-and-exception-vector-settings.htmlYou can determine the minimum reset vector offset by using the following equation:
minimum reset vector offset= (.sof image start address + .sof image size) in HEX
You can also try as per the document, set the Reset Vector offset to "0x01E00000".With that, you need to regenerate the Platform Designer to get the new ".sopcinfo" file and use it to create the new BSP and project.
To confirm you have the Reset Vector offset changed, you can view them when you add in the ".hex" when you try to create the ".jic" file:
- Farabi_Altera
Just to let you know that I am checking your case. will get back to you as soon as possible.
regards,
Farabi
- Farabi_Altera
I am sorry, I am replacing previous Application Engineer as he is no longer with us.
Can you try to follow this guide: https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset03/nios-ii-processor-booting-from-cfi-flash.pdf
regards,
Farabi
- SERMASWATHIKA
Contributor
Hi Farabi,
Ok, we will check and let you know.
i have checked the document which you have shared.
In that configuration, passive parallelx16 is mentioned,
but eval board which we are having is cyclonve v gt eval. In that manual , configuration is active serial mode
Is that ok to use the programming setup in this eval board?
- Farabi_Altera
Yes, of course you can use the AS(Active Serial) mode as your configuration.
AS mode is simpler, as it is directly programmed the flash from JTAG via FPGA.
regards,
Farabi
- Farabi_Altera
I have provide the answer, I will transfer this case to community now.
If you have new question, please raise another ticket. We will be happy to help.
regards,
Farabi
