SERMASWATHIKA
Contributor
2 years agoFW_CODE_NOT_WORKING_WHEN_CONFIGURED_FPGA_WITH_JIC_PROGRAMMING
Hi Team, We tried to check the jic file programming setup in Cyclone v gt eval board. For that we have created the system in FPGA design like this: nios ii reset and exception vector param...
Farabi_Altera
2 years agoHello,
Yes, of course you can use the AS(Active Serial) mode as your configuration.
AS mode is simpler, as it is directly programmed the flash from JTAG via FPGA.
regards,
Farabi
