Mikhail_a
3 years agoFPGA to HPS bridge on Agilex 7
Hello I'm trying to read and write from and to HPS SDRAM on Agilex 7 board I have this configuration of fpga2hps interface: On the other side I have two msgdma ip cores for MM to Stream and...
EBERLAZARE_I_Intel
3 years agoHi,
The rocketboards link is still down, also I found this KDB that might have relation with your issue:
https://www.intel.com/content/www/us/en/support/programmable/articles/000094603.html
Can you try to apply the git patch and see if that would fix your issue without renaming/removing the .rbf to be configured?
