Mikhail_a
3 years agoFPGA to HPS bridge on Agilex 7
Hello I'm trying to read and write from and to HPS SDRAM on Agilex 7 board I have this configuration of fpga2hps interface: On the other side I have two msgdma ip cores for MM to Stream and...
EBERLAZARE_I_Intel
3 years agoHi,
Apologies for the late responds, in the doc I provided last time, it mentioned at the most bottom page, we do need to disable all bridges in U-boot if we have enabled them manually, before booting to the kernel, there is an issue with the RBO server currently, you may access it another time and confirm:
https://www.rocketboards.org/foswiki/Projects/SettingUpAndUsingBridgesOnAgilex
I guess that demonstrate the behavior you're seeing? Do you see any other issue if you manually disable the bridges, every time your enabled it in U-boot?
