Mikhail_a
3 years agoFPGA to HPS bridge on Agilex 7
Hello I'm trying to read and write from and to HPS SDRAM on Agilex 7 board I have this configuration of fpga2hps interface: On the other side I have two msgdma ip cores for MM to Stream and...
EBERLAZARE_I_Intel
3 years agoHi,
Thanks for the info, I may need some time to digest it and I will get back to you.
Just to be sure again, you can do read/write to FPGA in Linux environment, if you do not configure the FPGA in U-boot in prior boot stage?
Mikhail_a
3 years agoYes, but at this moment FPGA should be already configured in the previous boot.
