First vhdl design, building a bit memory
Hi all,
I starting with vhdl, and build this first design,
Than I wrote to a cyclone II device and got this:
From this circuit, I was expecting that dff output goes high at DFF clock rising edge and stay high. But it goes low at clock rising edge even that clock signal doesn't feeds dff directly.
Could someone help with this? Any help apreciated.
I tried to simulate the design; there is a spike in the DFF_Clock that causes the output of signal DFF_output as shown in waveform.PNG.
You may consider to remove the JK FF and AND gate.
KhaiY
- KhaiChein_Y_Intel
- Mentz
Hi KhaiY,
I've changed my design, excluding AND gate and and some other changes and it worked,
thanks for your time and efforts
Mentz
- KhaiChein_Y_Intel
Could you share the design for investigation?What is the software edition/version you are using?
KhaiY
- Mentz
- KhaiChein_Y_Intel
KhaiY
