MBurk9's avatar
MBurk9
7 years ago
[Failed] while downloading non-volatile *.jic File into FPGA
There is a problem, in downloading a non-volatile *.jic File into FPGA.
Depending on *.sof, sof can download to the board.
The problem comes with jic file.
Maybe while converting, or writing on DE1-SoC.
Equipment:
- Board: DE1-SoC, 5CSEMA5F31C6, rev.G
- Quartus II, 18.1 Lite
- Example: Demonstrations\FPGA\my_first_fpga\my_first_fpga.qpf
Converting:
- jic
- EPCS128
- Active Serial
- Flash Loader: Cyclone V, 5CSEMA5
Programmer:
- Hardware-Setup: DE-SoC [USB-1]
- Mode: JTAG
- Autodetect
- File for EPCS128: Demo.jic
Between 35 - 75 %, the process Failed.
Is there something I can do?
Are there other possibilities for non-volatile configuration the FGPA-Board?
With a Cyclone II Board (Quartus II, 13.0sp1), I have no problem with *.pof File,
Mode Active Serial Programming.
  • JohnT_Altera's avatar
    JohnT_Altera
    Could you provide me the full Quartus message to understand what issue you are observing? How many device is in your chain?
    • MBurk9's avatar
      MBurk9
      Hi JohnT,
      thank you for response.
      The problem was a MSEL problem.
      The default MSEL = 10010 didn't work.
      To flash non-volatile, MSEL = 01001 works fine.
    JohnT_Altera
    I am glad that the issue is resolved. Could you confirm if your MSEL is correct?
    The reason is that MSEL = 10010 should the correct setting. Please double confirm if you the SW is high or low.
