MBurk9
7 years ago[Failed] while downloading non-volatile *.jic File into FPGA
There is a problem, in downloading a non-volatile *.jic File into FPGA. Depending on *.sof, sof can download to the board. The problem comes with jic file. Maybe while converting, or writing on DE...
JohnT_Altera
7 years agoHi,
I am glad that the issue is resolved. Could you confirm if your MSEL is correct?
The reason is that MSEL = 10010 should the correct setting. Please double confirm if you the SW is high or low.
