EMIF Location constraint error
- 1 year ago
Hello Adzim
I was able to resolve the above issue, by selecting the checkbox "Mimic HPS EMIF" in External Memory Interfaces (EMIF) IP wizard, if we want to connect EMIF in FPGA fabric to DDR4 component 1.
So now we can close this issue
regards
Madhur
Hello Adzim
The pin name is emif_fm_0_mem_mem_ck[1][0], because I was trying to instantiate two EMIF IPs connecting to DDR components comp 0 and comp 1 on Agilex board.
But even I try to connect one EMIF IP to comp 1 pin mapping, error still comes, while it doesn't come for comp 0 interface.
Even the error says "there are no valid locations in the region for logic of this type".
And then I found this below link, https://www.intel.com/content/www/us/en/content-details/656512/intel-agilex-7-i-series-agib027-device-pinouts-xlsx-format-alt-format-pdf.html
according which Comp 1 pin maps are tied to HPS_DDR. Can you please confirm the same.
regards
Madhur
