EMIF Location constraint error
- 1 year ago
Hello Adzim
I was able to resolve the above issue, by selecting the checkbox "Mimic HPS EMIF" in External Memory Interfaces (EMIF) IP wizard, if we want to connect EMIF in FPGA fabric to DDR4 component 1.
So now we can close this issue
regards
Madhur
Hi Madhur,
The connection here is connected to FPGA. Just the IP can do connection HPS.
If you use the HPS EMIF IP, then the FPGA should has connection to HPS.
If you use the FPGA EMIF IP, then the FPGA should not has connection to HPS.
The pin location is same for both IP in this case.
I think you need to set all pin location for EMIF interface similar to the schematic.
But the pin name is emif_fm_0_mem_mem_ck[1][0]. It is second CK pin in the IP?
The schematic only has 1 pair of CK pin. Is there any other CK pin in the design?
Adzim
