19 years agodifficulty regarding signal tap use
I am doing filtering of a signal.
i am using mega core library,nco compiler and fir filter block.i specified the parameters and generated the blocks in simulink, but i am not able to generate the specified output on the scope.i am geting no output on the scope. another problem is that i am using signal tap analysis in this design.i am not familiar with that block how to use it. please help me.3 Replies
What kit (if any) are you using?
Did you select the Development Board in the Simulink / Altera Signal Compiler? Mike - Altera_Forum
DSP development kit,cyclone 2 edition.
yes i selected the development board in the simulink/altera signal compiler. - Altera_Forum
First thing to check is the .PIN file generated by the Signal Compiler / QuartusII. Verify that the pin-out is correct. That has been a large problem with the DSP Builder / QuartusII setup.
If the pins are correct, try something much smaller using the QuartusII only environment; to ensure you have a good build setup. Mike
