19 years agodifficulty regarding signal tap use
I am doing filtering of a signal. i am using mega core library,nco compiler and fir filter block.i specified the parameters and generated the blocks in simulink, but i am not able to generate the ...
19 years agoWhat kit (if any) are you using?
Did you select the Development Board in the Simulink / Altera Signal Compiler? Mike
