19 years agodifficulty regarding signal tap use
I am doing filtering of a signal. i am using mega core library,nco compiler and fir filter block.i specified the parameters and generated the blocks in simulink, but i am not able to generate the ...
19 years agoFirst thing to check is the .PIN file generated by the Signal Compiler / QuartusII. Verify that the pin-out is correct. That has been a large problem with the DSP Builder / QuartusII setup.
If the pins are correct, try something much smaller using the QuartusII only environment; to ensure you have a good build setup. Mike
