prabhu1's avatar
prabhu1
2 years ago
Differential LVDS output clock voltage level settings
I am doing this test on development board : cycloneVE_5cefa7f31_fpga_v12_1_1_0
Pins _HSMC_TX_D_P0, HSMC_TX_D_N0 in bank 4( power 2_5v) are used and they are defined as LVDS (output). I am using differential probe (x50). Oscilloscope shows 5Vp_p.
The LVDS swing expected is 300mV. If the output swing measured was 5V, then there is something wrong in the set up or configuration ?
  • FvM's avatar
    FvM
    simple fault, LVDS output needs 100 ohm differential termination to see nominal level of 340 mV.
  • Farabi_Altera's avatar
    Farabi_Altera
    "We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    Thank you for your understanding."
    Farabi_Altera
    Please follow FvM suggestion to fix your LVDS issue.
    regards,
    Farabi
