kwkprd's avatar
kwkprd
2 years ago
Default status on IO pins after program.
Recently i have worked on probing the FMC in scope and seen a sine wave immediately after programming the FPGA sof having the prbs generator. i want to know the status of FPGA IO's after programing. In qsf file it is mentioned as HSSI IO standard pin mapping.
  • FvM's avatar
    FvM
    after programming, respectively in user mode, IOs are controlled by your design. All assigned IO pins take the state you have defined. Unassigned pins get a default state (e.g. tristated with weak-pullup) specified in Quartus Assignments/Device/Device and Pin Options/Unused Pins.
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    NazrulNaim_Intel
    As per user 'FvM' stated in the previous comment. The answer can be accepted, IO's are controlled by your design. All assigned IO pins take the state you have defined.
    Nazrul Naim
    NazrulNaim_Intel
    Nazrul Naim
