kwkprd
2 years agoDefault status on IO pins after program.
Recently i have worked on probing the FMC in scope and seen a sine wave immediately after programming the FPGA sof having the prbs generator. i want to know the status of FPGA IO's after programing. ...
FvM
2 years agoHi,
after programming, respectively in user mode, IOs are controlled by your design. All assigned IO pins take the state you have defined. Unassigned pins get a default state (e.g. tristated with weak-pullup) specified in Quartus Assignments/Device/Device and Pin Options/Unused Pins.
