Dear Team, Greetings!!! Can you please provide us the IPC class-6 documents for the below listed products. These were not available in material deceleration tool
This is for our customer VIASAT. I have attached the LOA for your reference
- Nooraini_Y_Intel
Hi Smude,
May I know which specific Intel FPGA or CPLD devices are you asking for the IPC document? Please do provide the device part number.
Thank you.
Nooraini
- SMude
Hi Nooraini, Thanks for your quick response. Below listed parts for which we need IPC class-6 documents for Full material declaration sheets. Customer Part Number Mfr Part Number Part Description 1295885 1SG085HN2F43I2VG IC,FPGA,STRATIX 10,850 K LES,48 XCVR,H-TILE,I TEMP,-2 SPEED,VID,1760 PINS,43 MM BGA,ROHS 1297525 1SG165HN2F43I2VG IC,FPGA,STRATIX 10,1624 K LES,48 XCVR,H-TILE,I TEMP,-2 SPEED, VID,1760 PINS,43 MM BGA,ROHS 1293963 1SG210HN2F43E1VG IC,FPGA,STRATIX 10GX,2100K LE,48 XCVRS,STD VID,H-TILE,ET,ROHS,FBGA1760 1295936 1SG210HU2F50E1VG IC,FPGA,STRATIX 10GX,2100K LE,96 XCVRS,H-TILE,ET,ROHS,FBGA2397 1302926 1SG280HN2F43E2VGS3 IC,STRATIX 10,FPGA,2.8M LES,H-TILE,48 XCVRS,ET,FBGA,1760 PINS,42.5X42.5MM,ROHS 1301696 1SG280HN2F43I2VGS3 IC,STRATIX 10,FPGA,2.8M LES,H-TILE,48 XCVRS,IT,FBGA,1760 PINS,42.5X42.5MM,ROHS 1300053 FTLX8571D3BCV-IT XCVR,FIBER OPTIC,SFP,1G/10G,850NM,3.3V,INTEL FTLX8571D3BCV-IT,ROHS Best Regards, [ihs.com]<https://ihsmarkit.com/> Santosh Mudengudi Sourcing Engineer | Des&Sup Chain-Parts 15 Inverness Way East | Englewood, Colorado | 80112 [email protected]<mailto:[email protected]> [Facebook]<http://facebook.com/Explore.IHS>[Twitter]<https://twitter.com/IHS>[LinkedIn]<http://linkedin.com/company/ihs>[YouTube]<http://youtube.com/ihschannel>[IHS Blogs]<http://blog.ihs.com/>[Google+]<https://plus.google.com/+IhsExplore> This email message, including accompanying communications and attachments, is strictly confidential, for the sole use of the intended recipient(s) and may contain privileged information. Any unauthorized use, review, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. Thank you. ?Please consider the environment before printing this e-mail. - Nooraini_Y_Intel
Hi Smude,
After checking internally, you can actually use the existing system to generate the IPC report by visiting this page:
http://www.altera.com/support/reliability/environmental/material-declaration/material-decl.html
Please refer to the attached screen shot. Thank you.
Nooraini
- SMude
Hi Yusof, Thanks, i tried it before submitting. Got an error indicating invalid part no,s. However these parts are valid. I was asked to raise a support request for IPC class 6 decleration. Regards, Santosh Get Outlook for Android<https://aka.ms/ghei36> - Nooraini_Y_Intel
HI SMude,
I will need some times to check on this within the internal teams. I will update here once I have further information.
Thank you.
Nooraini
- Nooraini_Y_Intel
Hi Smude,
I have feedback this request to the internal team. They are still working on to update the Stratix 10 reports since there are many Stratix 10 part numbers thus it will take time.
Regards.
Nooraini
- SMude
Dear Nooraini Greetings!!! Please provide an update on this request since this is pending for long time. Best Regards, [ihs.com]<https://ihsmarkit.com/> Santosh Mudengudi Sourcing Engineer | Des&Sup Chain-Parts 15 Inverness Way East | Englewood, Colorado | 80112 [email protected]<mailto:[email protected]> [Facebook]<http://facebook.com/Explore.IHS>[Twitter]<https://twitter.com/IHS>[LinkedIn]<http://linkedin.com/company/ihs>[YouTube]<http://youtube.com/ihschannel>[IHS Blogs]<http://blog.ihs.com/>[Google+]<https://plus.google.com/+IhsExplore> This email message, including accompanying communications and attachments, is strictly confidential, for the sole use of the intended recipient(s) and may contain privileged information. Any unauthorized use, review, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. Thank you. þPlease consider the environment before printing this e-mail. - Nooraini_Y_Intel
Hi Smude,
Greeting to you too. Have you tried to check from the existing system (in the link below) to generate the IPC report?
I can see there are already some Stratix 10 reports available from the system.
As mentioned previously, the internal team responsible on this will need time to update the Stratix 10 reports since there are many Stratix 10 part numbers. Let me know if you are still not able to generate the reports, then I will feedback to the internal team accordingly.
Nooraini
- SMude
Hi Nooraini, Thanks for your quick response. I tried , However it seems your internal team has not updated the reports. Since this is pending from long time can you please expedite the process as we need these documents. Best Regards, [ihs.com]<https://ihsmarkit.com/> Santosh Mudengudi Sourcing Engineer | Des&Sup Chain-Parts 15 Inverness Way East | Englewood, Colorado | 80112 [email protected]<mailto:[email protected]> [Facebook]<http://facebook.com/Explore.IHS>[Twitter]<https://twitter.com/IHS>[LinkedIn]<http://linkedin.com/company/ihs>[YouTube]<http://youtube.com/ihschannel>[IHS Blogs]<http://blog.ihs.com/>[Google+]<https://plus.google.com/+IhsExplore> This email message, including accompanying communications and attachments, is strictly confidential, for the sole use of the intended recipient(s) and may contain privileged information. Any unauthorized use, review, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. Thank you. þPlease consider the environment before printing this e-mail. - Nooraini_Y_Intel
Hi Smude,
Have you tried to check from the existing system (in the link below) to generate the IPC report for the FPGA devices? Please search using the valid part number and download the reports.
I can see there are already some FPGA Stratix 10 reports available from the system. Refer to the attached screen shots. According to the internal team, they can only generate and publish the reports for valid OPN that is ready for customer booking(ready to be manufacture).
1SG165HN2F43I2VG
1SG085HN2F43I2VG
As shown from the screen shot, the report will not be generate for any ES (Engineering Sample) devices. The report can only be generate for valid production device that are available for customer booking(ready to be manufacture). The internal team confirmed that they cannot generate+publish the reports for following devices that are either inactive OPN, ES (Engineering Sample) and invalid part number. The inactive OPN refers that these devices are not even available for customer booking (not being manufacture) thus there is no way the internal team can generate the report.
1SG210HN2F43E1VG --> inactive OPN
1SG210HU2F50E1VG ---> inactive OPN
1SG280HN2F43E2VGS3 --> ES (Engineering Sample)
1SG280HN2F43I2VGS3 --> invalid part number
I suggest that you should check with your customer how did they obtain the inactive OPN and invalid part number devices as those are not even available for customer booking.
Nooraini
