9 years agoDE1-SoC "my_first_HPS" tutorial
I want to use HPS on DE1-SoC board. I am following the instructions provided in the manual My First HPS. I downloaded and installed EDS under C:\altera\15.0 directory. When I type "Make"on the Embedded Command Shell, I get the error massage; 'Make' is not recognized as internal or external command ....... I searched for a Make.exe within C:\altera\15.0\embedded and there are several; I do not know which one to execute to compile my program, however I decided to execute this one:
C:\altera\15.0\embedded\ds-5\bin\Make I get a error message - se attached screen shot. Is this the right "Make" ? How to define a path for the right Make? My operating system is Windows 7 Thanks3 Replies
--- Quote Start --- I want to use HPS on DE1-SoC board. I am following the instructions provided in the manual My First HPS. I downloaded and installed EDS under C:\altera\15.0 directory. When I type "Make"on the Embedded Command Shell, I get the error massage; 'Make' is not recognized as internal or external command ....... I searched for a Make.exe within C:\altera\15.0\embedded and there are several; I do not know which one to execute to compile my program, however I decided to execute this one: C:\altera\15.0\embedded\ds-5\bin\Make I get a error message - se attached screen shot. Is this the right "Make" ? How to define a path for the right Make? My operating system is Windows 7 Thanks --- Quote End --- Hello, Could you please check if you have set the SOCEDS_DEST_ROOT environment variable as C:\altera\15.0\embedded or not? Barbara, - Altera_Forum
Thank you Barbara. Please tell me how do I check for the environment variable?
--- Quote Start --- Thank you Barbara. Please tell me how do I check for the environment variable? --- Quote End --- Hello, Please right click My Computer[/B],[/B] and select properties, and then click Advanced System Settings[/B][/B] and Environment Variables[/B][/B], then you can click Edit [/B][/B]to set the SOCEDS_DEST_ROOT environment variable as C:\altera\15.0\embedded. I attached the steps for your reference. Barbara,
