9 years agoDE1-SoC "my_first_HPS" tutorial
I want to use HPS on DE1-SoC board. I am following the instructions provided in the manual My First HPS. I downloaded and installed EDS under C:\altera\15.0 directory. When I type "Make"on the Embed...
9 years ago --- Quote Start --- I want to use HPS on DE1-SoC board. I am following the instructions provided in the manual My First HPS. I downloaded and installed EDS under C:\altera\15.0 directory. When I type "Make"on the Embedded Command Shell, I get the error massage; 'Make' is not recognized as internal or external command ....... I searched for a Make.exe within C:\altera\15.0\embedded and there are several; I do not know which one to execute to compile my program, however I decided to execute this one: C:\altera\15.0\embedded\ds-5\bin\Make I get a error message - se attached screen shot. Is this the right "Make" ? How to define a path for the right Make? My operating system is Windows 7 Thanks --- Quote End --- Hello, Could you please check if you have set the SOCEDS_DEST_ROOT environment variable as C:\altera\15.0\embedded or not? Barbara,
