13 years agoDE1 Problem
Hi guys,
I just got myself an Altera DE1 but i am having some issue with it. I have installed the USB blaster driver and Quartus II 7.2 that come with the CD accordingly. However, the problem still persist... The issue i am having now: 1) The console application included in the package is giving me an error message "download elf file DE1_ControlPanel.elf) fail!" at 95%. 2) I cant program the DE1_demonstrations provided in the CD to my Altera board. I am using the USB Blaster with JTAG. (first i compile the code, then i proceed to the programmer(select USB Blaster and JTAG then start the programming) is that the correct way to program the DE1 ? 3) I tried to start with the tutorial and other online tutorial. I can compile them but it doesnt generate the .sof file that it should. I cant find it anywhere on my laptop. I am very new with Altera board. :( Any help will be greatly appreciated! :) Thanks !!!3 Replies
for the first one: I get a similar error. I load the .sof file with Quartus and then click the connect button in the control panel. A bit more work, but it'll get you there (I think).
the second one: Do you have the right device selected? There might be a problem there, also you should make sure the programming switch is at the right position. (refer to manual for this. I think it is run. and for the thirf one: search this forum. I believe I have seen this before. It could be a setting somewhere. note: These are possible solutions. But since they all have to do with programming/sof files It could be there is a common problem for these issues. - Altera_Forum
--- Quote Start --- for the first one: I get a similar error. I load the .sof file with Quartus and then click the connect button in the control panel. A bit more work, but it'll get you there (I think). the second one: Do you have the right device selected? There might be a problem there, also you should make sure the programming switch is at the right position. (refer to manual for this. I think it is run. and for the thirf one: search this forum. I believe I have seen this before. It could be a setting somewhere. note: These are possible solutions. But since they all have to do with programming/sof files It could be there is a common problem for these issues.[/QUOT Thanks for the reply! I have tried out the suggested method but 1) It cant work for my case :( 2) I am pretty sure i selected the correct device and the programming switch 3) Thanks! I will do a search on the forum to get possible solution :) Thank you so much for your help ! :D - Altera_Forum
I solved this problem by installing the latest Quartus II 13.0.1. :D
Thanks guys!
