13 years agoDE1 Problem
Hi guys, I just got myself an Altera DE1 but i am having some issue with it. I have installed the USB blaster driver and Quartus II 7.2 that come with the CD accordingly. However, the problem ...
13 years ago --- Quote Start --- for the first one: I get a similar error. I load the .sof file with Quartus and then click the connect button in the control panel. A bit more work, but it'll get you there (I think). the second one: Do you have the right device selected? There might be a problem there, also you should make sure the programming switch is at the right position. (refer to manual for this. I think it is run. and for the thirf one: search this forum. I believe I have seen this before. It could be a setting somewhere. note: These are possible solutions. But since they all have to do with programming/sof files It could be there is a common problem for these issues.[/QUOT Thanks for the reply! I have tried out the suggested method but 1) It cant work for my case :( 2) I am pretty sure i selected the correct device and the programming switch 3) Thanks! I will do a search on the forum to get possible solution :) Thank you so much for your help ! :D
