14 years ago
DE0-Nano SDRAM Nios II JIC file won't work
Hello
I have configured my Nios II with SDRAM (no on-chip memory) with SOPC Builder on my DE0-Nano board (EP4CE22F17C6). All the code I wrote in Eclipse works perfectly when it's loaded from there.
To run my code from the EPCS64 chip I did the next steps:
- Right click the main project folder (not the BSP one) in Nios II
- Make Targets
- Build...
- Mem Init Install
- Build
- Then in Quartus, click the Compile Design button to get a SOF file that includes the FPGA configuration and the Nios Firmware.
- Then convert the SOF file into a JIC file by going to the File menu, Convert programming files
- Selected the SOF file and the correct FPGA model
- With the newly generated JIC file I programmed the EPCS64
After that, it seems that the Nios firmware is not being loaded.
Is this the correct method to program the EPCS64 when using SDRAM as the main memory for the Nios CPU?
Thanks!
