14 years agoDE0-Nano SDRAM Nios II JIC file won't work
Hello I have configured my Nios II with SDRAM (no on-chip memory) with SOPC Builder on my DE0-Nano board (EP4CE22F17C6). All the code I wrote in Eclipse works perfectly when it's loaded from th...
14 years agoIt seems that I have to add an EPCS Serial Flash Controller in the SOPC module. By doing so, I will be able to move firmware from the EPCS to the SDRAM that the Nios is working with.
More info here: http://www.altera.com/literature/ug/ug_embedded_ip.pdf
