Cyclone VGT Dev Kit boards - some new boards failing to boot from NOR Flash
Hi Leonardo,
Thank you for sharing your findings.
As this thread is focused on GordWait's investigation, could you please open a new thread for your boards? This will help us track your case separately and avoid mixing debug information from different systems.
Please include the board serial numbers, revision, U29 component, and observed behavior in the new post.
Hi Gord,
Thank you for the detailed analysis.
Please submit an RMA request through the distributor that supplied each affected board:
DigiKey or Mouser: provide the board serial number, purchase details, and factory-image boot failure.
Terasic: follow Terasic’s RMA process and state that the board does not boot reliably with the unmodified factory MAX V image.
Affected boards retry or fail with the factory max5.pof and a simple 25 MHz bootloader, indicating a hardware issue.
Please retain the serial numbers, boot observations, and relevant logs.
Fakhrul
