Cyclone V Dev Kit - pin file
Is there some sort of pin file that Quartus can input to assign I/O pins for a given eval board instead of manually entering them?
I'm working on this Cyclone V dev kit
- sstrell
You can download and install a design template for your board, which should have the pinout set up for you. You can then customize for your own design:
https://fpgacloud.intel.com/devstore/platform/?acds_version=any&board=24
- AR_A_Intel
Hello
Yes, you can check and customize your design based on example in our Design Store.
- AR_A_Intel
We have not heard from you and I hope all is well. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
