mjszekely
5 years agoCyclone V Dev Kit - pin file
Is there some sort of pin file that Quartus can input to assign I/O pins for a given eval board instead of manually entering them?
I'm working on this Cyclone V dev kit
https://www.intel.com/con...
sstrell
5 years agoYou can download and install a design template for your board, which should have the pinout set up for you. You can then customize for your own design:
https://fpgacloud.intel.com/devstore/platform/?acds_version=any&board=24
