13 years agoCyclone V - JTAG ID Error - download failed
I meet JTAG error while downloading the .sof file to the FPGA via "Programmer". It says that the JTAG Id isn't what the Programmer was expecting for. I use Cyclone V devloppement kit and Quartus II v.13 (64-bit). What can I do to avoid it ? (Screenshots are attached to this post). Thanks, https://www.alteraforum.com/forum/attachment.php?attachmentid=7650 https://www.alteraforum.com/forum/attachment.php?attachmentid=76517 Replies
I have the same problome.
Please help! - Altera_Forum
I am seeing a similar problem with the Cyclone V GT demo board, annoyingly on the GT demo board you have to have the MAX V CPLD system controller in the JTAG chain with the FPGA which is not like the GX demo board.
When I scan the JTAG chain it automatically detects the FPGA and CPLD correctly but when I try and load a sof in the FPGA and bypass the CPLD it fails. Does anyone know how to resolve this one? - Altera_Forum
Hi guys,
Actually, my former problem is solved. JTAG ID Error occured because of unconstrained in/out of my design. To avoid it, make sure that all your in/out have a pin_location assigned. regards, - Altera_Forum
Hi Basstudio,
Does your programmation start a few or not at all ? If yes, at how many percentage does the fail appear ? - Altera_Forum
Thanks arriacinq but this is fine in my design.
The QuartusII programmer gets to 95% and then reports: --- Quote Start --- Error (209040): Can't access JTAG chain Error (209015): Can't configure device. Expected JTAG ID code 0x02B040DD for device 1, but found JTAG ID code 0x00000000. Error (209012): Operation failed --- Quote End --- Interestingly if I connect an old USB Byte Blaster to the JTAG header on the demo board (this automatically disables the embedded USB-Blaster-II) it works :confused: - Altera_Forum
The USB-Blaster II on the Cyclone V board runs at 16MHz by default (unless you have a very old board in which case its default speed is set to 24MHz).
Does turning the speed down to 6MHz with the command below make things more reliable? jtagconfig --setparam <cable id> JtagClock 6M You can use --getparam to read the current speed. - Altera_Forum
Interestingly I have got a what I think is a new Cyclone V GT development board because it has the updated silicon and it reported a JTAG speed of 24MHz.
I have now issued the config --setparam to 16MHz and see if that makes a difference, oddly it does work but not reliably - SignalTap usually causes it to go wrong.
