14 years agoCyclone IV GX, DDR decoupling
I'm actually doing schematics using the cyclone Iv gx evaluation board. I placed the same DDR2( Mircon MT47H16M16) but I wonder why there are only 40 caps (10x4 CN caps) when micron says to put caps on every signals ? Are theses caps only needed for DQ DQS and DM ?6 Replies
Post the schematics, but I suppose You're talking about caps after termination resistors to Vref?
These are required, but not necessary. The more, the better, but usually there is no requirement to overload the PCB with caps.
Ok, fine.
However, if these caps are required but not necessary, for which signals are they required for, to the extent there are only 40 caps but 61 ddr2a signals ? - Altera_Forum
These caps are placed to keep Vref plane as much clean as possible. You should add a cap near every termination resistor, but since You're probably using resistor networks (at least I did), then place at least one cap per resistor network. The common approach is to place 3 caps near one resistor network with values: 100nF, 10nF, 1nF.
Understood. Thank you for explanation.
