14 years agoCyclone IV GX, DDR decoupling
Hi, I'm actually doing schematics using the cyclone Iv gx evaluation board. I placed the same DDR2( Mircon MT47H16M16) but I wonder why there are only 40 caps (10x4 CN caps) when micron says t...
14 years agoThese caps are placed to keep Vref plane as much clean as possible. You should add a cap near every termination resistor, but since You're probably using resistor networks (at least I did), then place at least one cap per resistor network. The common approach is to place 3 caps near one resistor network with values: 100nF, 10nF, 1nF.
