16 years ago
Cyclone III Starter Kit - DDR-SDRAM - help
I'm newbie user in FPGA and I need to read and to write in DDR-SDRAM from Cyclone III starter kit.
I altered the QB3 example (.bdf).
And I created a new project in Nios II loading the .ptf file from cycloneIII_3c25_start_niosII_standard_sopc.ptf.
I program a little code for test, bu I don't have success.
Somebody can help me ?
Rester
    It looks like a hardware problem on the sdram access.
    Is the sof file the reference one given with the kit, or did you recompile it yourself?
    --- Quote Start ---
    It appears memory bit failed to be verified at data bit 0x01 sort of msg in console
    --- Quote End ---
    I also had this problem once, the cause of this error was the use of a false base adress. When you are, for example, using a clock crossing bridge, you get an absolute and a relative base adress and it is very important to use the absolute base adress in the memtest application.
    That solved the problem for me (I'm not a specialist myself, just trying to help...)
    There's a picture of the SOPC builder in the attachment that shows what I mean.
    Good luck!
    Best,
    Hans
