16 years agoCyclone III Starter Kit - DDR-SDRAM - help
I'm newbie user in FPGA and I need to read and to write in DDR-SDRAM from Cyclone III starter kit. I altered the QB3 example (.bdf). And I created a new project in Nios II loading the .ptf f...
16 years ago --- Quote Start --- It appears memory bit failed to be verified at data bit 0x01 sort of msg in console --- Quote End --- I also had this problem once, the cause of this error was the use of a false base adress. When you are, for example, using a clock crossing bridge, you get an absolute and a relative base adress and it is very important to use the absolute base adress in the memtest application. That solved the problem for me (I'm not a specialist myself, just trying to help...) There's a picture of the SOPC builder in the attachment that shows what I mean. Good luck! Best, Hans
