17 years agoCyclone III-Control_Panel problem, dll not found
I am trying to install control panel for cyclone III starter kit, but having problems. It installs succesfully (v7.2) but when i try to run the control panel, it gives the following error. This application has failed to start because jtag_client.dll was not found. Re-installing the application may fix this problem. and after i press OK, it gives fail to load dll C:\Altera\72\kits\cycloneIII_3c25_start\demos\cycloneIII_3c25_start_control_panel\software\alt_jtaglib.dll and finally after pressing OK to this gives fail to connect to developement kit.. I have tried to install it again and again but not successful. Kindly help me in this regard Thanks Saqib6 Replies
I get the same exact problem. I have windows XP. Has anyone have a solution to this?
Thanks. - Altera_Forum
Same problem here, with version 8.0, running on Vista. This topic is half a year old, hopefully somebody has a solution! Thank you, Johan - Altera_Forum
After a whole lot of digging I was able to figure out what the problem was. I had to do two things:
1) Copy over jtag_client.dll and dinkum_alt.dll from "QUARTUS_ROOT_DIR\quartus\bin" to the Control Panel software folder. 2) Add the following two directories to my windows system PATH variable: C:\altera\10.0\nios2eds\bin C:\altera\10.0\nios2eds\bin\nios2-gnutools\H-i686-pc-cygwin\bin Step 1 was courtesy of Terasic's tech support and has now been added to their technical FAQ webpage. Step 2 I figured out on my own and essentially consisted of having to go through each script and running them all manually until I figured out where they were failing. I have no idea why it is that some people have to do this fix and some people don't. Some people have no problems at all. Weird. Just FYI, my system is Windows 7 64-bit running Quartus and NIOS II EDS v10.0. Hope this helps someone in the future. Pz! Jonathon - Altera_Forum
@Jonatho...so much thank to your post .. its really very good and easy dll missing (http://www.articlewritingclicks.com/errors/dll2.php) solution you have provide ....
I had a similar problem -- jtag_client.dll and other Quartus libraries could not be found when running software that was trying to use them. I found that my Quartus bin directory was not in my PATH environment variable. This was very strange because I know for a fact that it used to be in my PATH.
Anyway, after adding the directory to the PATH env var (the directory in my case was C:\altera\91\quartus\bin) the problem went away. Hope this helps! LH - Altera_Forum
--- Quote Start --- Hi, I am trying to install control panel for cyclone III starter kit, but having problems. It installs succesfully (v7.2) but when i try to run the control panel, it gives the following error. This application has failed to start because jtag_client.dll was not found. Re-installing the application may fix this problem. and after i press OK, it gives fail to load dll C:\Altera\72\kits\cycloneIII_3c25_start\demos\cycloneIII_3c25_start_control_panel\software\alt_jtaglib.dll and finally after pressing OK to this gives fail to connect to developement kit.. I have tried to install it again and again but not successful. Kindly help me in this regard Thanks Saqib --- Quote End --- That helped for me .
