17 years agoCyclone III-Control_Panel problem, dll not found
Hi, I am trying to install control panel for cyclone III starter kit, but having problems. It installs succesfully (v7.2) but when i try to run the control panel, it gives the following error. ...
14 years ago --- Quote Start --- Hi, I am trying to install control panel for cyclone III starter kit, but having problems. It installs succesfully (v7.2) but when i try to run the control panel, it gives the following error. This application has failed to start because jtag_client.dll was not found. Re-installing the application may fix this problem. and after i press OK, it gives fail to load dll C:\Altera\72\kits\cycloneIII_3c25_start\demos\cycloneIII_3c25_start_control_panel\software\alt_jtaglib.dll and finally after pressing OK to this gives fail to connect to developement kit.. I have tried to install it again and again but not successful. Kindly help me in this regard Thanks Saqib --- Quote End --- That helped for me .
