17 years agoCyclone II DSP Develpment Kit . Analysis & Synthesis Error
I'm using Altera DSP Develpment Kit, Cyclone II Edition. Reference Design Number: AN427. I do Analysis & Synthesis very well at Quartus II 6.0. But, when I change the following parameters in Scaler V1.0.0 IP: -- Select: Enable image clipping. -- Width 100, X offset 10. -- Height 100, Y offset 10. and do generate at Matlab 7.1. Then, return to Quartus II 6.0, there are errors while Analysis & Synthesis. The error message are: Error: Port "spaceavail_en" does not exist in macrofunction "fu_msgs_read_to_write_main" .. and other more 7 errors just like that. Please give me instruction to solve these problems. Thanks! Kevin Ding 2008.0924.Wed2 Replies
Try to upgrade Quartus II to the latest release. You can download it freely from the Altera website.
The higher version could not let the lab reference project loaded well.
The IP is not licensed, but I just wanna evaluation before purchase license. When I click the Error Msg (port "dataavail_en" does not exist in macrofunction "fu_msgs_read_to_write_main") it indicates to file my_tbb.vhd, hilight to: fu_msgs_read_to_write_main : ALT_FIFO GENERIC MAP (NAME=>"fu_msgs_read_to_write_main", WIDTH=>2, DEPTH=>2, ADDRESS_WIDTH=>1, FAMILY=>FAMILY, SIMULATION=>SIMULATION, MANUFACTURER=>MANUFACTURER, OPTIMIZED=>OPTIMIZED) PORT MAP (clock=>clock, reset=>reset_int, ena_read=>ena_thread_0, ena_write=>ena_thread_1, stall_write=>S_fu_msgs_read_to_write_main_stall_write, stall_read=>S_fu_msgs_read_to_write_main_stall_read, writenext_en=>fu_msgs_read_to_write_main_writenext_en, readnext_en=>fu_msgs_read_to_write_main_readnext_en, wdata=>fu_msgs_read_to_write_main_wdata, writenext=>fu_msgs_read_to_write_main_writenext, readnext=>fu_msgs_read_to_write_main_readnext, rdata=>fu_msgs_read_to_write_main_rdata, dataavail=>fu_msgs_read_to_write_main_dataavail);
