qwitza's avatar
qwitza
9 months ago
Cyclone 5 first boot linux crashes, howto debug?
We have a design with a Cyclone V FPGA. Some boards only boot after a reset following power-on.
Problem:
The Debian Linux with U-Boot boots from the SD card, but after approximately 10 seconds, the system crashes and becomes unresponsive. The login prompt appears (on UART debug), but I cannot enter anything, and the network interface does not work.
How should I start troubleshooting?
There is a JTAG on the board, but I have never used it until now.
Any hints or links would be greatly appreciated.
Sorry, but I have no idea how to resolve this, or where to start with the troubleshooting.
  • qwitza's avatar
    qwitza
    i think we can not change to partial, because we have only the free version.
    i am right?
    greetings
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Any update on this case?
    Did you try out the suggestion in the previous comment?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Could you change the rpd to partial?
    It would need to be partial as the full configuration could cause the HPS to reconfigured too.
    When the HPS is configured the linux running will alsoo crashes, I believe what is happening currently in your case.
    Jingyang, Teh
    • qwitza's avatar
      qwitza
      i am right?
      greetings
    tehjingy_Altera
    Hi
    Do you have any follow up question from the previous comment?
    Jingyang, Teh
    • qwitza's avatar
      qwitza
      we do not write the rpd partially it is a full flash.
      The kernel also offers this option.
    tehjingy_Altera
    Hi
    After checking, it seems this is not officially tested for the Cyclone5.
    However we could try to get it to work on your end.
    The problem could be you not setting the Cyclone5 to have partial reconfiguration?
    https://www.intel.com/content/www/us/en/docs/programmable/683694/current/dynamic-reconfiguration-25100.html
    The configuration during the linux should only be on the FPGA fabric and not reconfigure the HPS.
    You could not reconfigure the HPS when running in linux.
    Jingyang, Teh
  • qwitza's avatar
    qwitza
    here is the source code, how we "upload" the fpga firmware.
    if(is_no_error())
    	std::ofstream wpd("/sys/kernel/config/device-tree/overlays/device/path");
    	wpd << "socfpga_overlay.dtb"";
    	wpd.close();
    	if(wpd.fail())
    		return ERROR_WRITE_FAIL;
    tehjingy_Altera
    Hi
    Is it possible to share how you flash the FPGA firmware?
    In normal case we do not suggest to flash the FPGA firmware after we boot into the linux console.
    Jingyang, Teh
    • qwitza's avatar
      qwitza
      uboot and debian are booted every time.
      but after writing the fpga firmware debian crashes, no input or other possible hard crash
      9.697986] socfpga-dwmac ff702000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
      [ 9.706611] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      Debian GNU/Linux 10 ttyS0
      login: [ 37.347805] fpga_manager fpga0: writing socfpga.rbf to Altera SOCFPGA FPGA Manager
      login: [ 1477.077961] socfpga-dwmac ff702000.ethernet eth0: Link is Down
      if i disable the fpga firmware flash, it seems that the system bootup every time. the fpga firmware is written via devicetree update.
      thanks for the help!
  • qwitza's avatar
    qwitza
    after some search, it seems that the linux system crashes after writing the fpga firmware.
