If the device is not recognized, you may have hardware issue. I received 3 of these Cyclone 10 GX development kit. I am using the same PC. 2 of them successfully work without any problem. Third one only recognize the flash device but not FPGA. I am returning the failed one.
--- Quote Start --- I just received my board. But running jtagconfig it seems like it does not properly detect the device:jtagconfig --version Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition Copyright (C) 2017 Intel Corporation. All rights reserved.
It detects the other devices I have connected to the host "zappa". Also running BoardTestSystem.sh results in a Java related error:jtagconfig 1) CV SoCKit on zappa 02D020DD 5CSEBA6(.|ES)/5CSEMA6/.. 4BA00477 SOCVHPS 2) USB-Blaster on zappa 020F40DD 10CL040(Y|Z)/EP3C40/EP4CE30/.. 3) USB-BlasterII on zappa 031820DD 10M08SA(.|ES)/10M08SC 02E120DD ! Captured DR after reset = (0063041BB02E120DD) Captured IR after reset = (0AAD55) Captured Bypass after reset = (2) Captured Bypass chain = (2) JTAG clock speed 24 MHz
Did anybody have similar results with this board? It did not come with any software but I downloaded it from the link above in this thread. --- Quote End ---Error: Could not find or load main class com.intel.bts.BtsApp - Altera_Forum
Thank you for your reply. But it seems like it's able to detect the jtag id 02E120DD. Do you see the same id on your board when you run jtagconfig?
Fortunately it seemed to be a software problem. Seem to be that jtagd on my programming host "zappa" hasn't been restarted in a long time. So it never loaded the more recent pgm_parts.txt file. After re-starting jtagd it can identify the device:
And programming using quartus_pgmw worked fine from one of my build hosts.jtagconfig 1) CV SoCKit on zappa 02D020DD 5CSEBA6(.|ES)/5CSEMA6/.. 4BA00477 SOCVHPS 2) USB-Blaster on zappa 020F40DD EP3C40/EP4CE(30|40) 3) USB-BlasterII on zappa 031820DD 10M08SA(.|ES)/10M08SC 02E120DD 10CX220Y - Altera_Forum
I managed to get java configured correctly so the BoardTestSystem.sh is up and running. But unfortunately it seem to assume that the board is connected to the local host (i.e. the one running the java application) and does not support jtag over the network like quartus_pgm, system_console, jtagconfig, etc
Is there a way to enable remote access in the board tests system java app? - Altera_Forum
During my previous invocation I got an error:
After re-starting the java app it probed the devices over the network and the statsus was "Board Connected. Then I managed to read the temps and the voltages using the app, but then it died again:Caused by: java.lang.NullPointerException
Restarting it I can't seem to connect again:Apr 29, 2018 11:30:53 AM com.altera.avalon_i2c.I2CCont readReg16 SEVERE: addr 0x5c, reg 0x5 java.lang.Exception: Write, NO ACK Shunt Voltage Register read error: 0xffff Bus Voltage Register read error: 0xffff
The java app seem to be a bit unstable.Apr 29, 2018 11:35:11 AM com.intel.bts.JtagInfo createDeviceInfoMapArray SEVERE: java.io.IOException: : get_service_paths device
