9 years agoCyclone 10 GX PCIe dev kit?
Are there any Cyclone 10 GX PCIe dev kits available or will any such dev kits be available soon?
8 years agoIf the device is not recognized, you may have hardware issue. I received 3 of these Cyclone 10 GX development kit. I am using the same PC. 2 of them successfully work without any problem. Third one only recognize the flash device but not FPGA. I am returning the failed one.
--- Quote Start --- I just received my board. But running jtagconfig it seems like it does not properly detect the device:jtagconfig --version
Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition
Copyright (C) 2017 Intel Corporation. All rights reserved.
jtagconfig
1) CV SoCKit on zappa
02D020DD 5CSEBA6(.|ES)/5CSEMA6/..
4BA00477 SOCVHPS
2) USB-Blaster on zappa
020F40DD 10CL040(Y|Z)/EP3C40/EP4CE30/..
3) USB-BlasterII on zappa
031820DD 10M08SA(.|ES)/10M08SC
02E120DD !
Captured DR after reset = (0063041BB02E120DD)
Captured IR after reset = (0AAD55)
Captured Bypass after reset = (2)
Captured Bypass chain = (2)
JTAG clock speed 24 MHz
It detects the other devices I have connected to the host "zappa". Also running BoardTestSystem.sh results in a Java related error: Error: Could not find or load main class com.intel.bts.BtsApp
Did anybody have similar results with this board? It did not come with any software but I downloaded it from the link above in this thread. --- Quote End ---
