manishkumar's avatar
manishkumar
2 years ago
Cyclone® V FPGA – Remote System Upgrade over UART Based on Nios® II Processors with EPCQ Design Exam
with given reference design example try to program the output_file.jic file through Quartus prime programmer as per the reference user manual in to the (Cyclone V E FPGA Development Kit)
, but it is failed to program giving error:
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
Error (209012): Operation failed
Note: 1) using the output_file.jic given in design example (no changes)
2) using (Cyclone V E FPGA Development Kit)
unable to program the given reference design example. Kindly provide the solution for this
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
  • totolo's avatar
    totolo
    I encountered the same issue, the JIC programming failed, and I can't even erase the flash. The component at the U2 position on my C5E development board is not an EPCQ256 but a 2WA15 RW164. How should I deal with this?
