14 years ago
Compile error on BEMicro SDK tutorial
I am new to the BE Micro SDK and i am doing the tutorial and I'm having a compile error of this nature. Could anyone help me with that.
Error (12006): Node instance "u0" instantiates undefined entity "nios2_bemicro_system"
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 1 error, 2 warnings
Error: Peak virtual memory: 324 megabytes
Error: Processing ended: Thu Jul 26 11:15:16 2012
Error: Elapsed time: 00:00:04
Error: Total CPU time (on all processors): 00:00:02
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 2 warnings
Kind regards
Malvin Maduna
    Sorry I can't help with your error. I was looking for help also.
    I followed the lab pdf closely and got through the qsys section without an issue. But I get 4 compiler errors after that.
    I am using Quartus II V12. The lab pdf says version 10 November 2010.
    Any ideas?
    Info (176444): Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices
    Info (176445): Device EP4CE10F17A7 is compatible
    Info (176445): Device EP4CE10F17C7 is compatible
    Info (176445): Device EP4CE10F17I7 is compatible
    Info (176445): Device EP4CE6F17A7 is compatible
    Info (176445): Device EP4CE6F17I7 is compatible
    Info (176445): Device EP4CE15F17A7 is compatible
    Info (176445): Device EP4CE15F17C7 is compatible
    Info (176445): Device EP4CE15F17I7 is compatible
    Info (176445): Device EP4CE22F17A7 is compatible
    Info (176445): Device EP4CE22F17C7 is compatible
    Info (176445): Device EP4CE22F17I7 is compatible
    error (169130): configuration mode specified as remote but remote update block is not found in design
    Info (171121): Fitter preparation operations ending: elapsed time is 00:00:00
    Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information.
    Error (171000): Can't fit design in device
    Error: Quartus II 32-bit Fitter was unsuccessful. 2 errors, 4 warnings
    Error: Peak virtual memory: 342 megabytes
    Error: Processing ended: Fri Jul 27 23:01:41 2012
    Error: Elapsed time: 00:00:00
    Error: Total CPU time (on all processors): 00:00:01
    Error (293001): Quartus II Full Compilation was unsuccessful. 4 errors, 5 warnings
    --- Quote Start ---
    Kind regards
    Malvin Maduna
    --- Quote End ---
    Hi there,
    You need to include all the related files into your design as during compilation all the design files should be there.
    Best of luck,
    Nadia
