14 years agoCompile error on BEMicro SDK tutorial
I am new to the BE Micro SDK and i am doing the tutorial and I'm having a compile error of this nature. Could anyone help me with that. Error (12006): Node instance "u0" instantiates undef...
14 years agoSorry I can't help with your error. I was looking for help also.
I followed the lab pdf closely and got through the qsys section without an issue. But I get 4 compiler errors after that. I am using Quartus II V12. The lab pdf says version 10 November 2010. Any ideas? Info (176444): Device migration not selected. If you intend to use device migration later, you may need to change the pin assignments as they may be incompatible with other devices Info (176445): Device EP4CE10F17A7 is compatible Info (176445): Device EP4CE10F17C7 is compatible Info (176445): Device EP4CE10F17I7 is compatible Info (176445): Device EP4CE6F17A7 is compatible Info (176445): Device EP4CE6F17I7 is compatible Info (176445): Device EP4CE15F17A7 is compatible Info (176445): Device EP4CE15F17C7 is compatible Info (176445): Device EP4CE15F17I7 is compatible Info (176445): Device EP4CE22F17A7 is compatible Info (176445): Device EP4CE22F17C7 is compatible Info (176445): Device EP4CE22F17I7 is compatible error (169130): configuration mode specified as remote but remote update block is not found in design Info (171121): Fitter preparation operations ending: elapsed time is 00:00:00 Warning (171167): Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information. Error (171000): Can't fit design in device Error: Quartus II 32-bit Fitter was unsuccessful. 2 errors, 4 warnings Error: Peak virtual memory: 342 megabytes Error: Processing ended: Fri Jul 27 23:01:41 2012 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:01 Error (293001): Quartus II Full Compilation was unsuccessful. 4 errors, 5 warnings
