16 years ago
Character LCD on DSP Development Kit, Stratix III Edition
Hi all,
does anyone have VHDL code for printing on the character LCD of the DSP Development Kit, Stratix III Edition board ?
Thanks!
Francesco
    You can use some signaltap probes to see what is sent to the LCD controller and check if it is ok.
    How high is your clk frequency? If it is coming directly from the oscillator it is probably too high. You should use a counter in your process and only update your signals (including lcd_enable) only every n clock cycles.
    And while I'm at it, try to use ieee.numeric_std with the "unsigned" and "signed" types instead of ieee.std_logic_unsigned. It is standard and will cause less confusion when mixing unsigned and signed vectors.
    file:///C:/Users/DELLCE%7E1/AppData/Local/Temp/moz-screenshot.png file:///C:/Users/DELLCE%7E1/AppData/Local/Temp/moz-screenshot-1.png i did special clk that get 25mhz and output 100khz
    but also no output.can u please check the code to see whats not good
    file:///C:/Users/DELLCE%7E1/AppData/Local/Temp/moz-screenshot-2.png file:///C:/Users/DELLCE%7E1/AppData/Local/Temp/moz-screenshot-3.png Please help me the clock is ok but the problem in lcd code
    here the code of the clk
    library IEEE;
    use IEEE.STD_LOGIC_1164.all;
    use IEEE.STD_LOGIC_ARITH.all;
    use IEEE.STD_LOGIC_UNSIGNED.all;
    ENTITY clk_div IS
    PORT
    clock_25Mhz : IN STD_LOGIC;
    clock_1MHz : OUT STD_LOGIC;
    clock_100KHz : OUT STD_LOGIC;
    clock_10KHz : OUT STD_LOGIC;
    clock_1KHz : OUT STD_LOGIC;
    clock_100Hz : OUT STD_LOGIC;
    clock_10Hz : OUT STD_LOGIC;
    clock_1Hz : OUT STD_LOGIC);
    END clk_div;
    ARCHITECTURE a OF clk_div IS
    SIGNAL count_1Mhz: STD_LOGIC_VECTOR(4 DOWNTO 0);
    SIGNAL count_100Khz, count_10Khz, count_1Khz : STD_LOGIC_VECTOR(2 DOWNTO 0);
    SIGNAL count_100hz, count_10hz, count_1hz : STD_LOGIC_VECTOR(2 DOWNTO 0);
    SIGNAL clock_1Mhz_int, clock_100Khz_int, clock_10Khz_int, clock_1Khz_int: STD_LOGIC;
    SIGNAL clock_100hz_int, clock_10Hz_int, clock_1Hz_int : STD_LOGIC;
    BEGIN
    PROCESS
    BEGIN
    -- Divide by 25
    WAIT UNTIL clock_25Mhz'EVENT and clock_25Mhz = '1';
    IF count_1Mhz < 24 THEN
    count_1Mhz <= count_1Mhz + 1;
    ELSE
    count_1Mhz <= "00000";
    END IF;
    IF count_1Mhz <= 12 THEN
    clock_1Mhz_int <= '0';
    ELSE
    clock_1Mhz_int <= '1';
    END IF;
    -- Ripple clocks are used in this code to save prescalar hardware
    -- Sync all clock prescalar outputs back to master clock signal
    clock_1Mhz <= clock_1Mhz_int;
    clock_100Khz <= clock_100Khz_int;
    clock_10Khz <= clock_10Khz_int;
    clock_1Khz <= clock_1Khz_int;
    clock_100hz <= clock_100hz_int;
    clock_10hz <= clock_10hz_int;
    clock_1hz <= clock_1hz_int;
    END PROCESS;
    -- Divide by 10
    PROCESS
    BEGIN
    WAIT UNTIL clock_1Mhz_int'EVENT and clock_1Mhz_int = '1';
    IF count_100Khz /= 4 THEN
    count_100Khz <= count_100Khz + 1;
    ELSE
    count_100khz <= "000";
    clock_100Khz_int <= NOT clock_100Khz_int;
    END IF;
    END PROCESS;
    -- Divide by 10
    PROCESS
    BEGIN
    WAIT UNTIL clock_100Khz_int'EVENT and clock_100Khz_int = '1';
    IF count_10Khz /= 4 THEN
    count_10Khz <= count_10Khz + 1;
    ELSE
    count_10khz <= "000";
    clock_10Khz_int <= NOT clock_10Khz_int;
    END IF;
    END PROCESS;
    -- Divide by 10
    PROCESS
    BEGIN
    WAIT UNTIL clock_10Khz_int'EVENT and clock_10Khz_int = '1';
    IF count_1Khz /= 4 THEN
    count_1Khz <= count_1Khz + 1;
    ELSE
    count_1khz <= "000";
    clock_1Khz_int <= NOT clock_1Khz_int;
    END IF;
    END PROCESS;
    -- Divide by 10
    PROCESS
    BEGIN
    WAIT UNTIL clock_1Khz_int'EVENT and clock_1Khz_int = '1';
    IF count_100hz /= 4 THEN
    count_100hz <= count_100hz + 1;
    ELSE
    count_100hz <= "000";
    clock_100hz_int <= NOT clock_100hz_int;
    END IF;
    END PROCESS;
    -- Divide by 10
    PROCESS
    BEGIN
    WAIT UNTIL clock_100hz_int'EVENT and clock_100hz_int = '1';
    IF count_10hz /= 4 THEN
    count_10hz <= count_10hz + 1;
    ELSE
    count_10hz <= "000";
    clock_10hz_int <= NOT clock_10hz_int;
    END IF;
    END PROCESS;
    -- Divide by 10
    PROCESS
    BEGIN
    WAIT UNTIL clock_10hz_int'EVENT and clock_10hz_int = '1';
    IF count_1hz /= 4 THEN
    count_1hz <= count_1hz + 1;
    ELSE
    count_1hz <= "000";
    clock_1hz_int <= NOT clock_1hz_int;
    END IF;
    END PROCESS;
    END a;
    We can't see your screenshots... please either attach them to a message or use an image hosting service.
    The way that you generate the clock isn't really recommended for FPGAs. It is better to do everything on the 25MHz clock, using clock enables if necessary. In your code if you have glitches on the internal clock signals, the counters can count faster than expected and you won't get the frequency that you want.
    Printing characters on LCD without using SOPC, Nios etc AND by using just DSP BUILDER is the main thing I'm aiming at. I've already posted a similar message on DSP Builder section but hasn't been answered yet. I'd be happy if someone solves this puzzle for us.
