18 years agoCan't get SRAM IDT71V416 work on Nios II dk Stratix II edition
Hi to all,
If I use the standard IDT71V416 controller on a niosII_stratixII_2s60ES development board (two chip in parallel for 32 bit data bus) it works well. But with my custom controller compliant to datasheet (tcl code follows) I get "verify failed" in execution but the memory test (MemTest) works great. Can anyone help? Thank you. # TCL File Generated by Component Editor 7.2sp1 on: # Wed Mar 19 14:53:42 CET 2008 # DO NOT MODIFY # Blackbox -- The top level is not based on an HDL file set_source_file "" set_module "idt71v416" set_module_description "" set_module_property "editable" "true" set_module_property "group" "User Logic" set_module_property "instantiateInSystemModule" "false" set_module_property "version" "1.0" # Module parameters # Interface global_signals_clock add_interface "global_signals_clock" "clock" "sink" "asynchronous" # Ports in interface global_signals_clock add_port_to_interface "global_signals_clock" "clk" "clk" set_port_direction_and_width "clk" "input" "1" add_port_to_interface "global_signals_clock" "reset_n" "reset_n" set_port_direction_and_width "reset_n" "input" "1" # Interface avalon_tristate_slave_0 add_interface "avalon_tristate_slave_0" "avalon_tristate" "slave" "global_signals_clock" set_interface_property "avalon_tristate_slave_0" "isNonVolatileStorage" "false" set_interface_property "avalon_tristate_slave_0" "readLatency" "0" set_interface_property "avalon_tristate_slave_0" "readWaitStates" "10" set_interface_property "avalon_tristate_slave_0" "holdTime" "0" set_interface_property "avalon_tristate_slave_0" "printableDevice" "false" set_interface_property "avalon_tristate_slave_0" "readWaitTime" "10" set_interface_property "avalon_tristate_slave_0" "setupTime" "0" set_interface_property "avalon_tristate_slave_0" "writeWaitTime" "10" set_interface_property "avalon_tristate_slave_0" "timingUnits" "Nanoseconds" set_interface_property "avalon_tristate_slave_0" "minimumUninterruptedRunLength" "1" set_interface_property "avalon_tristate_slave_0" "activeCSThroughReadLatency" "false" set_interface_property "avalon_tristate_slave_0" "isMemoryDevice" "true" set_interface_property "avalon_tristate_slave_0" "writeWaitStates" "10" set_interface_property "avalon_tristate_slave_0" "maximumPendingReadTransactions" "0" # Ports in interface avalon_tristate_slave_0 add_port_to_interface "avalon_tristate_slave_0" "data" "data" set_port_direction_and_width "data" "bidir" "32" add_port_to_interface "avalon_tristate_slave_0" "addr" "address" set_port_direction_and_width "addr" "input" "18" add_port_to_interface "avalon_tristate_slave_0" "cs_n" "chipselect_n" set_port_direction_and_width "cs_n" "input" "1" add_port_to_interface "avalon_tristate_slave_0" "oe_n" "read_n" set_port_direction_and_width "oe_n" "input" "1" add_port_to_interface "avalon_tristate_slave_0" "we_n" "write_n" set_port_direction_and_width "we_n" "input" "1" add_port_to_interface "avalon_tristate_slave_0" "be_n" "byteenable_n" set_port_direction_and_width "be_n" "input" "4"2 Replies
Ok, I resolved with the help of user Fischer from Niosforum.
The controller doesn't understand a address setup time of 0ns: at least 1ns is needed despite what the datasheet says. Thanks to all - Altera_Forum
Right. I think I suffered from the same confusion at first. Even though the SRAM chip may have a 0 ns setup, the signal still have to travel through IO buffers and PCB traces, so real-life setup is more than 0. For the similar reason, you can't run a 10 ns async SRAM at 100 MHz. However, for _synchonous_ sram it's a different story.
