SKacc
6 years agoCan we able to operate system clock of FPGA with 25MHz or 50MHz input?
Arria V Device Overview(AV-51001) says the input reference clock ranges from 27MHz to 710MHz.
- AnandRaj_S_Intel
Hi Srikanth,
Yes, you can have a 25 MHz or 50 MHz system/global clock for FPGA. And use PLL to generate the required clock frequency for other design modules (ddr/transceivers/ADC).
Refer respective datasheet under the clock-tree session.
Anand
- SKacc
Datasheet says global or regional clock frequency is either 625 or 525 MHz only. (Document ref: AV_51002, Page No 44).
- AnandRaj_S_Intel
That is a max frequency that you can have for the global or regional clock.
- You can have a 25 MHz or 50 MHz system/global clock for FPGA. And use PLL to generate the required clock frequency for other design modules
