Can the FIR II IP core coefficients be left uninitialized?
Hello everyone,
I am using a MAX 10 SC device.
I instantiated an FIR II IP core with 2 coefficient banks.
The implementation features the interface to let the coefficients being loaded through memory mapped accesses.
When I try to run the Analysis & Synthesis step on Quartus 17.0, the tool raises an error stating:
"Error (16031): Current Internal Configuration mode does not support memory initialization or ROM. Select Internal Configuration mode with ERAM."
I looked on other forums at it seems that the problem relies on the configuration option (Assignments > Device > Device and Pin Options...).
There I should select the configuration mode Single uncompressed image with Memory Initialization.
This mode is not available on MAX 10 SC (Single Supply/Compact) devices, hence I need to instantiate the IP without initializing the coefficient banks.
Is there any way to achieve this?
Samuele Favazza
- JohnT_Altera
Hi, think the FIR II IP core contain memory initialization where you might need to modify the code in order to remove the memory initialization.- SFava
Do you refer to the automatically generated sources for the FIR II IP core?
If yes, could you point me to the code that I should manually change?
Above all I think the Quartus tool, should warn the user about this potential issue as it is aware of the device being used for the design.
Samuele Favazza
- JohnT_Altera
Yes, I am referring to the generated file. Could you share with me the generated file?
- SFava
- JohnT_Altera
HI,
If you go to "fir_tdm\fir_tdm\synthesis\submodules\" folder then in fir_tdm_fir_compiler_ii_0_rtl_core.vhd it will include 2 hex file which is needed to be initialize by the FIR II IP. I am not sure if you delete the initialization file then will the functionality works or not. I would recommend you to use DC device.
