SFava
7 years agoCan the FIR II IP core coefficients be left uninitialized?
Hello everyone, I am using a MAX 10 SC device. I instantiated an FIR II IP core with 2 coefficient banks. The implementation features the interface to let the coefficients being loaded through mem...
JohnT_Altera
7 years agoHi,
think the FIR II IP core contain memory initialization where you might need to modify the code in order to remove the memory initialization.
SFava
7 years agoDo you refer to the automatically generated sources for the FIR II IP core?
If yes, could you point me to the code that I should manually change?
Above all I think the Quartus tool, should warn the user about this potential issue as it is aware of the device being used for the design.
Samuele Favazza
