11 years ago
Can not load examples fro MAX10 dev kit
Bought the max10 dev kit and cannot get any of the design files to load. Down loaded the .par files and they will not run. Found an obscure post that you have to download the .par then run a number of cmd scripts to create the other files. Is there a folder that has all of the files required to run a given design example ? I cannot even get the files for the program that is in the dev kit to run.
    --- Quote Start ---
    You need to prepare the design template as explained in the design store page. Either prepare the design template using the Quartus II GUI or the command line.
    https://cloud.altera.com/help/devstore/
    --- Quote End ---
    I downloaded the dev kit files but can not find a .qpf file for the max10 development system software that is loaded on the board I bought.
    If you have prepare the design template there should be some folders generated containing .qpf.
    I have a similar problem.
    I follow the instructions from the dev store, but the downloaded program produces zero (0) indication that it's doing anything.
    special note, those example had to strictly follow on specific quartus version. example if u using 15.0, please do not download a 14.1 examples, it won;t work.
