Can LVDS clock pin be assigned to general differential IO?
Hi experts,
We are using LVDS with internal PLL, on 10M50 board. Is there a hard requirement that LVDS tx/rx clock pin should be assigned to a dedicate clock pin?
Is there any violations or bad impact if we assigned it to general differential IOs?
I got such error if I assigned it to general differential IO pin. Is there any workaround for it?
Error (176554): Can't place PLL "ioc_top:ioc_top_inst|lvds_rx:lvds_rx_inst|altera_soft_lvds_rx_sXRJHsuO:lvds_rx_inst|lvds_rx_pll" -- I/O pin lvds_clk_in (port type INCLK of the PLL) is assigned to a location which is not connected to port type INCLK of any PLL on the device
- SreekumarR_G_Intel
Hello there ,
Can it possible to share the design to look at in details ?
Thank you ,
Sree
- Jiayi_H_Intel
Here is the example module instantiate LVDS:
module top (
input lvds_clk_in,
output lvds_clk_out,
input lvds_rx_in,
output lvds_tx_out
lvds_rx lvds_rx_inst (
.rx_inclock (lvds_clk_in), // rx_inclock.rx_inclock
.rx_in (lvds_rx_in), // rx_in.rx_in
.rx_out (lvds_rx_data), // rx_out.rx_out
.rx_data_align (bit_slip_sync2), // rx_data_align.rx_data_align
.rx_outclock (rx_outclock), // rx_outclock.rx_outclock
.pll_areset (!lvds_rstn), // pll_areset.pll_areset
.rx_locked (rx_locked) // rx_locked.rx_locked
lvds_tx lvds_tx_inst (
.tx_in (lvds_tx_data), // tx_in.tx_in
.tx_out (lvds_tx_out), // tx_out.tx_out
.tx_outclock (lvds_clk_out), // tx_outclock.tx_outclock
.tx_coreclock (tx_coreclock), // tx_coreclock.tx_coreclock
.tx_inclock (clk_100_max10), // tx_inclock.tx_inclock
.tx_locked (tx_locked)
endmodule
Here is pin assignment with Good/Bad assign, Device : 10M50DAF484C6GES
#hsmc_clk_in =============== Good Pin assignment
set_location_assignment PIN_V10 -to lvds_clk_in
set_location_assignment PIN_V9 -to lvds_clk_in(n)
#hsmc_clk_in =============== Bad Pin assignment
#set_location_assignment PIN_W6 -to lvds_clk_in
#set_location_assignment PIN_W5 -to lvds_clk_in(n)
#hsmc_clk_out
set_location_assignment PIN_W8 -to lvds_clk_out
set_location_assignment PIN_W7 -to lvds_clk_out(n)
#hsmc_rx
set_location_assignment PIN_V5 -to lvds_rx_in
set_location_assignment PIN_V4 -to lvds_rx_in(n)
#hsmc_tx
set_location_assignment PIN_W3 -to lvds_tx_out
set_location_assignment PIN_W4 -to lvds_tx_out(n)
Looks like Pin V9 and V10 is dedicated clk input , whereas W5 and W6 is not . PLL inclk should be from the dedicated clk pin.
You can try to use the altclkbuf cntrl ip option. This might help to connect the non-dedicated input clk pin to clk tree in the FPGA.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altclock.pdf
