Jiayi_H_Intel
6 years agoCan LVDS clock pin be assigned to general differential IO?
Hi experts, We are using LVDS with internal PLL, on 10M50 board. Is there a hard requirement that LVDS tx/rx clock pin should be assigned to a dedicate clock pin? Is there any violations or bad im...
SreekumarR_G_Intel
6 years agoLooks like Pin V9 and V10 is dedicated clk input , whereas W5 and W6 is not . PLL inclk should be from the dedicated clk pin.
You can try to use the altclkbuf cntrl ip option. This might help to connect the non-dedicated input clk pin to clk tree in the FPGA.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altclock.pdf
